Promotion
Divya198990
Just actived my new SIM and $40 plan, but didnt get $10 off on my plan
10 REPLIES 10
marimacas
If you are talkking about $10 Refer-a-friend one time credit, it will be reflected on your account within 72 hours, and you will receive a text mnessage from PM.
In my case, I received $10 credit and the message the next morning.
Aaaaand, 5hrs. later, and nary a peep out of the OP..... guess they must've figured it out.....
popping
We are giving all possible answers to OP's question.
Let see who wins the solution lottery.  lol
@popping , the only doubt here was inserted by @CannonFodder 😁
popping
We are guessing again what OP's issue is...
As  @CannonFodder  points out the refferal code $10  credit usually appears within 72 hours. 👍Fodder out 😉
@CannonFodder wrote:
Everybody seems to be assuming the OP is talking about the recent Lunar New Year promo, rather than the $10 credit for using someone's referral code.....
hycm53
It looks like the promotion is over, feel bad for you.
gblackma
@Divya198990 the lunar promotion ended at 11.59pm est on February 3rd. When did you activate your SIM card?  If you activated before, then the first $10 Will be placed in your account within 30 days.  And the promotion applied in months 2 to 9. Welcome to PM.
If after, then, sorry but you missed it.
Staliger
@Divya198990  That's okay. You will get it within 30 days if you activated it before 23:59 of 3rd Feb. Will apply for 2-9th months of service.
