11-22-2016 01:16 AM - edited 01-05-2022 12:48 AM
Service
11-22-2016 01:30 AM
This case, it seems that the plan is switched successfully between two PM phone numbers. Without knowing how two numbers are set up (whether under one account or separate), it is hard to tell whether your case would be same or not.
This case, it seems the change was successful, but one account is to be closed. Moderator says " We usually do not switch plans or phone number in between accounts." so eligibility of switching plan would be case by case.
Conclusion: doesn't hurt to try! 😉
11-22-2016 01:26 AM
11-22-2016 01:26 AM
Not always impossible. Give me few minutes. I am collecting previous cases.
11-22-2016 01:22 AM
Your husband's and your accounts are not linked, so you would not be able to transfer his data over. The plan is linked to the phone number. If you want to use his data, you'll have to put his SIM card into your phone, but that means you'll have to use his number.
11-22-2016 01:21 AM
11-22-2016 01:20 AM
If you ordered SIM today, you wouldn't be able to get the promo plan unfortunately as their program ended.. Instead, you can try to stick to $40/mth 2GB plan until there is new great promo if you would like. Once there is new promo, you can future date the promo plan.
11-22-2016 01:18 AM
Nope, the promo period only goes up until November 20th. They are honoring the promo plan for users that ordered prior to November 20th but have yet to receive their SIM card.
Unfortunately, you missed the boat 😞
