Problem with transferring number.
SYDNEYPLETT
So I tried to transfer my number from a different provider and when I type in the number at PM app it says Number Not Valid.  The previous provider plan is still active but it’s a prepaid plan at Lucky M.  Not sure what to do.  I currently have a temporary plan at PM and everything else works fine.  The old number still works to text at Lucky.
1 REPLY 1
@SYDNEYPLETT
Most numbers can be ported over from any carriers but there are a few numbers that you can’t port over.
Best to have a CS_Agent to look into this for you.
