Problem with US Roaming
yvinogradov
Purchased a text-talk-250mb roaming plan for the US
Got the the US but nothing works. Android phone. Data Roaming option is turned on. The phone is showing that it's connected to T-Mobile - there is icon up on top and also when I dig deeper into the phone's info and look at the SIM card data it's showing as connected to T-Mobile with roaming on and the carrier's signal present. When I try to make a phone call it drops the connection to T-Mobile, the connection comes back a few seconds later. Same thing with trying to send a text - drops the connection which comes back. Same with using data (trying to use WhatsApp for example). I've restarted the phone multiple times, same results.
This is not the first time I am using US roaming with this phone, it had always worked fine before. I also tried inserting my sim card into my wife's phone - same results.
Any fresh ideas are much appreciated
Thank you!
30 REPLIES 30
