07-27-2022
06:57 PM
07-30-2022
02:16 PM
Dunkman
When I tried to submit a ticket to get support, I got a 404 error so the bot told me to send a private message. Where should I expect yhe response to my message and how long usually does the response take?
Thank you
07-27-2022 08:36 PM - edited 07-27-2022 08:37 PM
It's weird you are getting an error code for area code 404, as that is the Area code for the city of Atlanta in the USA, an area which public mobile doesn't service. The closest area code to that in Canada is 403, which is for Calgary Alberta.
07-27-2022 07:01 PM
@Tkopoulos hi check your community envelope top right corner of this page ,it should be within an hour or two
07-27-2022 06:59 PM - edited 07-27-2022 07:29 PM
