Pricing
07-28-2017 02:27 PM - edited 01-05-2022 02:31 AM
07-29-2017 06:21 PM
For more data it is possible to look into going down data package and getting an add-on for more data. Depending on your need for data and possible ability to have add-on data to possible roll over to the next billing period.
07-28-2017 08:21 PM
What you see is what you get with this service. There is no negotiations like with other providers.
07-28-2017 07:59 PM
As others have mentioned, if you're ok with their 3G with its speed limit, that's the best way to go. Otherwise you'll have to wait for a better plan and just pony up the cash for now.
I find myself watching my usage carefully (12GB every 90 days) and so far so good, but I certainly couldn't live with less.
07-28-2017 03:17 PM
07-28-2017 02:38 PM - edited 07-28-2017 02:38 PM
I would say you if don't much care about lte plan then you can do with 3g plan you will be able to get 12gb plus 6gb bonus total of 18 gb data but on 3g for 156 plus tax on 90 days cycle.
07-28-2017 02:32 PM - edited 07-28-2017 02:33 PM
Here's all the plan are
https://publicmobile.ca/en/on/plans
Check it out and if you like something then contact mod. Also pm changed their plan structure so check new plan all the way before make any changes to your current plan.
Send a private msg
Add
Email address
Phonenumber
Detailed explanation of issue
