Prepaid visa
10-15-2018 01:16 PM - edited 01-05-2022 05:54 AM
10-15-2018 02:15 PM
If you are unable to use the card with PM then you coudl always buy a voucher online from recharge.com and use that to top up.
10-15-2018 01:43 PM
Visa Gift cards are a no-go in general.
I have a prepaid Visa from Scotiabank, which I reload with funds as required, and I have been using it for over 2 years now with Public Mobile, my prepaid internet provider, Amazon purchases, etc...
I had to apply at a local Scotiabank branch to get the card, but otherwise, it was a breeze.
10-15-2018 01:21 PM
@Ktraverse wrote:Am i able to pay my account with a reloadable prepaid visa card?
As it works like a visa debit that PM accepts, it should be good.
What you could do is put the funds on the card then use the card to but a credit in your PM account. If that works then you can add the card to autopay.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
10-15-2018 01:19 PM
Apparently you can. See this past example.
If this solves your question, please select my reply as Solution!
