04-11-2023 05:36 PM
I had an issue with porting and sent a message to CS admin. They have not gotten back to me. Are they closed for business hours today? I need to get my phone sorted out.
Service
04-11-2023 06:13 PM
Happy to hear @hTideGnow was able to help you out.
04-11-2023 06:08 PM
I will concede I don't know the exact process involved with porting from PC Mobile but is related to telus formerly owning the postpaid side of the provider.
As far as koodo prepaid it's always been my understanding that the phone number is not ported but merely transferred from the koodo prepaid account to the pm account back end. Since the telus porting department does not have account access I don't understand how they can help with "porting" from koodo prepaid. Has something changed or have I misunderstood this process for the past 3 1/2 years?
04-11-2023 05:51 PM
@maximum_gato wrote:As long as your account isn't from PC mobile or a koodo prepaid account you can call the telus porting department to sort out your porting issue. I will send you the phone number via private message.
The porting department could still help with porting from PC mobile or Koodo prepaid. The only restriction with porting from those two brands is how porting can't be done during the time of Public Mobile activation or from Self Serve.
04-11-2023 05:40 PM
hi @dkstkd there is a porting team you can call. I will message yiu the number. Check Community inbox. Call the team and they can provide you update or retrigger the process
04-11-2023 05:40 PM - edited 04-11-2023 05:40 PM
