09-05-2020 08:55 PM - edited 01-05-2022 01:06 PM
after I had problems porting my rogers number to my new phone to PM, how do I know when my number has been posted??
09-05-2020 10:34 PM
Did you try powering off your phone after inserting new PM sim card?
09-05-2020 09:41 PM
@regred1960 wrote:Oh, do you know how the support number works like #611? I thought I get a person but all sort of things they offer there
It's an automated system.
You can redeem vouchers, make payments using a pre-registered payment card, buy add-ons (with your PIN), toggle autopay (with your PIN).
That's about it. You can't do anything with pre-registered payment cards. You can't do anything else with your account.
09-05-2020 09:37 PM
Thank you very much. Yes I'm talking right now to the moderator team. Took me a while to find that help page but I hope I won't forget.
Thanks again.
09-05-2020 09:26 PM
@regred1960 Did you already contact moderators to give them the required info?
Here’s how to contact the Moderator Team:
If your port is not yet complete, continue to monitor your inbox (message envelope at top right corner) to look for their reply.
09-05-2020 09:08 PM
thanks. Hope I get it working soon
09-05-2020 08:57 PM - edited 09-05-2020 08:57 PM
@regred1960 wrote:after I had problems porting my rogers number to my new phone to PM, how do I know when my number has been posted??
When an incoming call rings on the phone with the PM SIM in it.
09-05-2020 08:56 PM
Porting can take a few hours to be completed.
Usually, if you can receive texts and phone call at your old number, then your port is completed successfully. Another way to find out is continue to use your Roger's SIM card and when it stops working, you can try your PM Sim card.
