07-20-2018 06:19 AM - edited 01-05-2022 05:08 AM
I've just activated a new SIM and asked for porting my number from CHATR.
It seems it is not succesfull, because I received a SMS that said that I need to complete my request to move to Public Mobile and complete SIM & Activation. "You'll need to provide the correct password or PIN from previous service provider".
I cannot complete that SIM activation form again, because the email address is already registered. When I first registered, I already gave the PIN from CHATR. That number is displayed in my CHATR account as "PIN code (4 digits)".
I don't know why it don't work and what should I do at this point.
07-20-2018 05:00 PM
From my own experiences, you will need your account and phone numbers from Chatr for sure. Occasionally, it might require your pin code as well. This is not a constant but happened to me when I was switching out from 7-11 (Speakout).
Good luck.
07-20-2018 08:32 AM
@oldrinba I would call chatr and ask your your account number and confirm that they have he correct spelling on file for your name.
Armed with those 2 pieces I wouldessagevmodsvsnd ask them to resubmit the port
07-20-2018 08:12 AM
@oldrinba, can you try simply doing a login to the self serve to see if you can submit the port a second time from within your account which is likely to have been successfully created during the first attempt at activation and porting. Failing that, definitely message the moderator team for further assistance.
07-20-2018 07:13 AM
You will need to send a private message to @CS_Agent to update a port request
As Chatr is raising existing clients prices probably seeing more of these this month ![]()
