06-18-2018 01:47 AM - edited 01-04-2022 06:12 PM
Hi,
i received text saying porting successful. However incoming calls still goes to my old phone. Can mod help me?
thanks!
Joining Public
06-18-2018 01:51 AM - edited 06-18-2018 01:53 AM
If you want help from a moderator, you can send a private message to Moderator_Team.
But for your porting issue, it could take a few hours for everything to work correctly. In my case it took about 2 hours. You can also try the following:
- restarting your phone
- powering off your phone and removing the SIM, then re-insert it
- go into your phone's Cellular network settings and manually selecting Public Mobile as your Network Operator
