01-24-2026 07:59 PM
My number was ported in from CTExcel today 4 hours ago. Outgoing calls and SMS work, but inbound calls do not reach my device. Anyone suggestions or similar experience? Thanks
01-24-2026 08:01 PM
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
01-24-2026 08:01 PM
hi @noose
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
