Porting failed
Erik5
Received the "We're having trouble transferring your request. Looks like you entered an incorrect ESN/MEID. I then received the eSIM activation failed message. However, I did get the text from FIZZ asking me to confirm the porting request. To which I replied YES.
Am I able to just retrigger the porting request and provide account number as opposed to the IMEI number? Will this resolve both issues? If so, how do I get this resolved?
1 REPLY 1
@Erik5
Yes, best to provide Fizz account number instead of IMEI for better success
There is a number to call to talk to live support,  you can provide them the missing info and  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
