Porting away from PM
ekam
Hi, I was wondering if I wanted to port away from PM would I be eligible for a refund for the remainder of the service I paid for?
Thanks!
daredogg
If you've decided to port away from PM, make sure to disable autopay, so that you're not charged. Once you get closer to end date of your current plan, I'd port then.
Just wondering if you saw the Fall 2016 promotion that gives you 12GB of data for $120 on a 90-day plan? Limited Time 4GB / $40 Plan Promo launching October 25th!
Also, can I ask why you're thinking of leaving PM? If there's something the community can do to resolve any issues, let us know.
maaji
As PM is a pre paid service, I do not think you will get a refund.
ute1978
As PM is a prepaid service there will be no refunds.
