03-18-2020 12:16 AM - edited 01-05-2022 11:10 AM
To whom it may concern,
I have 2 PM accounts, $15 (10 minutes/250MB) and $40 (5GB/$30 for 8 months), and would like to close out the $15 account and port its number over to the $40 account. Please advise on the best method to do so.
Thanks in advance,
Lan
Service
03-18-2020 12:26 AM - edited 03-18-2020 12:33 AM
No Canadian provider will allow porting number between accounts within one provider.
PM is no exception. You can swap number between PM accounts.
You need to port out the $15 plan number to another provider. Then, port it back to your $40 plan.
Your $15 plan will be cancel as soon as you port the number to another provider.
When you port your number back to the $40 plan, the $40 plan number will be gone.
03-18-2020 12:25 AM - edited 03-18-2020 12:26 AM
@geopublic wrote:@lannangbui Cannot be done directly as PM does not allow porting numbers between accounts.
The only way to do it would be to port out the $15 account to another provider and then port it in to the $40 plan.
Keep in mind that you should only use the above method if you don't care about the phone number that is currently attached to the $40 plan. When you port a number in to that account, the number that is already there will be lost.
03-18-2020 12:20 AM
