08-23-2016 08:59 AM - edited 01-04-2022 12:59 PM
Yesterday I had finally joined Public Mobile, switching over from Wind.
However, when I tried to port my existing phone number during activation, it has given me an error. I made sure to keep my Wind number/account active (no outstanding balances, paid till August 24) and my old account number handy for the transfer.
Upon trying to port many times without success and I was eager to try Public Mobile, I activated anyway with a new number knowing I am able to port my old number over later. Similar to yesterday, I am following the instructions to port my number in Plan Add-Ons > Change Phone Number but still received the error "You must be authorized to transfer this phone number". I am the main owner of my Wind account so I am unsure why the port is not working? I had two phones attached to my Wind account and one of those numbers ported to another carrier before mine, I hope Wind is not giving me issues because they flagged me in some way?
My Wind billing cycle ends on August 24 so I would really hope to resolve this porting number issue before that date if possible 😞 Any help or assistance would be greatly appreciated!
P.S. Trying Public Mobile for a day, I must say I am loving it! it is so nice to have reception in buildings again!
Cheers 🙂
04-23-2019 04:44 PM
@kho123 any news?
04-22-2019 01:59 PM
@kho123 wrote:my number was not working since he was porting
@kho123 are you saying you can't receive phone calls and texts after porting? If it's been more than about 3 hours since you submitted the port request (from another mobile provider--or 7 days if you are porting from a home phone or VoIP line), then see here to learn how to contact the moderator team via community private message to for them to assist with your failed port: How to Get Help - Community
04-22-2019 01:35 PM
07-25-2018 11:11 AM
@dougmcleod64111, I'd gladly assist you with this matter. Please get back to me with the requested information in the private message I sent you.
Thank you for your patience!
Aïssata
07-25-2018 03:51 AM - edited 07-25-2018 04:00 AM
Hi @dougmcleod64111 In order to get help with your problem, send a private message to the moderators explaining your situation.
If you don’t remember your PIN, check if it is still in your text history. It is texted it to you when you first set up the account. You can also provide any 3 of the following instead of your PIN: Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount.
07-25-2018 03:25 AM
The phone number ported on activation is incorect. The number is what showed as the alternate and the transfer of my existing cell number will not process on the change number request. How can I porcess the correction?
My cell phone is now showing my "alternate" home wired phone number instead of the cell number intented to transfrer.
Doug
12-14-2016 05:30 PM
Hey @LordSloth,
I'm sorry we couldn't get back to you earlier!
First, to make sure that your port goes through smoothly, I would recommend that you make sure that you have the authorization of your employer and from Bell to port it. You should also ask Bell which information they require for the port to go through successfully. Usually, your Bell account number is all you need but since you seem to have a special account/plan, you should double check.
Then, I would follow some of the very helpful guides here in the Community to make sure your activation and port are hassle free 🙂 (here's one example)
Don't hesitate to send me a private message if you need anything!
Saray
12-06-2016 11:01 AM - edited 12-06-2016 11:02 AM
Hi
I plan on porting my cell phone when I retire from the Goverment in late December. On that date I will be removing the Bell SIM, and replacing it with the Public Mobile SIM (and yes I did check compatibility). The phone is out of contract and older than three years, so I can legally take it with me in retirement.
Timing is critical on this, as I must capture the bell phone number before Bell throws the old number away on Dec xx , so that Public Mobile can capture it and port it.
Also, I don't own the number outright, and a Deparment Coordinator, will probably be needed to release the number, even although they are going to throw away the number anyways.
How do I ensure that this goes smoothly, and when should I inititiate the request?
Thanks
11-26-2016 09:18 PM
I am having the same issue, personal messaged you ! Thanks.
11-25-2016 05:00 PM
I have the similar issue, and send private message to Shazia and some others, however, no response from last Thursday. Can someone help?
11-25-2016 03:52 PM
11-25-2016 03:50 PM
I sent you a message a little while ago, please see it everything should be good in the next 30 minutes.
Thanks,
Shazia
11-25-2016 03:49 PM
11-25-2016 01:09 PM
I need some help here please.
Tried to pm MODs but no answer.
Looks like the port # transfer... isnt 100% fullfiled
i can make calls but cant receive. its very important to receive calls!!!!!
PLEASE Help or Cancel.
IGNORING IS NOT AN OPTION
11-13-2016 09:01 PM
11-13-2016 07:38 PM
11-13-2016 07:37 PM
Hi @srlawren thank you for your help! I checked the authorized box first and it let me through.
Just a a comment to others who are experiencing issues, I submitted my request but it said that they were experiencing issues and to contact moderators. However, 30 minutes later I received a text from PM saying that the transfer has been completed. Everything seems to be working now!
11-13-2016 06:56 PM
@agnesaurus try this...
sign into self-serve and go to Plans and add-ons, then Change PHone Number
Tell it you want to transfer in a phone number.
On the next step, make sure you check the "I am authorized ..." checkbox FIRST, and then enter your Fido phone number and click the button to check eligibility
On the next step, enter in only your Fido account number, an alternate phone number you can be reached at (home #, work #, partner/spouse's #, parent's #, etc) and in the last field put in the Fido account holder's name exactly as it appears on your Fido statements or Fido self-serve account.
11-13-2016 06:15 PM - edited 11-13-2016 07:38 PM
@Shazia_K Hi Shazia, I am experiencing the same issue trying to port from Fido. It says I am not authorized to transfer the phone number but my account is in good standing and I am the sole owner/user of that line. Please help. Thanks in advance.
EDIT: it's working now. Thanks! FIXED
08-24-2016 02:20 PM
08-24-2016 02:18 PM
08-24-2016 01:46 PM
Welcome aboard, @coconutcreampie! Glad to hear your issue was resolved promptly. Cheers!
08-24-2016 12:26 PM
I just wanted to post an update to this thread that my issue has been resolved! A huge thanks to @Shazia_K and those who have tried to assist.
What a great and helpful community - I am very happy to have switched to Public Mobile!
08-23-2016 10:23 PM
08-23-2016 10:21 PM
Didn't get a chance to get on the PC all day but will send a private message to you now @Shazia_K.
Thank you for all the helpful replies everyone! Hopefully I'll be out of Wind by end of the day tomorrow if all goes well. 😄
08-23-2016 08:51 PM - edited 08-23-2016 08:54 PM
Hey @antmorocks I'm sorry you're having trouble @Mary_M or @Shazia_K should be able to help you out in the morning. Sorry again, and welcome to the PM family.
08-23-2016 08:46 PM
Hi I think I have this exact same issue as I am coming over from chatr as well! Would someone be able to help?
08-23-2016 08:45 PM
08-23-2016 08:44 PM
Hi I think I have this exact same issue as I am coming over from chatr as well! Would someone be able to help? @Shazia_K
08-23-2016 12:19 PM
