Porting Eliglibility
fch
I am with public mobile and wanted to move my wife over to PM as well. She is currently with Koodo PREPAID service.
I do know that public mobile has issues when porting from Koodo and one should get a temp number first and then submit request for porting.
However, I wanted to make sure that her Public Mobile will be able to port the number and I will not end up wasting $120 to sign up and then find out it is not possible.
Using my public mobile account, when I go into "Phone Number Change" option and enter her phone number under "Check Eligibility", I get the following error....
"We are experiencing difficulties in processing this request. Please contact Public Mobile for additional assistance."
If I type in any other number (home or other cell), it says eligible.
How do I find out that public mobile will be able to port my wife's 647 number?
8 REPLIES 8
koimr1
@monk-key wrote:
Hello Mary Moderator, can you help me with the same.  I was just with Koodo Prepaid and my number should have been ready to Port In. but sadly it is still not eligible.. please help.
Hey @monk-key!
Just in case the mods don't see this, send them a private message by clicking here!
Include your email address and phone number that you're trying to port over as well as a brief description ("my Koodo number is ineligible! Help!") and they will definitely sort it out for you. 🙂
Best of luck and welcome to PM!
monk-key
monk-key
How did you get your Koodo number to become eligible.  I still can't get mine to be.
fch
I did received the response that my number is eligible to port from Koodo Prepaid.
Thank You for quick response.
fch
Any update on this request before I sign up? I have PM'ed the phone number yesterday morning to Mary_M. Is there anything else that I need to do to receive a response?
fch
I have just PM'ed the number to check.
Rockdaddy22
I don't see why it would be a problem. Just follow Mary's advice, she'll help you out.
Mary_M
Retraité / Retired
Retraité / Retired
Hello @fch
Thank you for reaching out to us!
Is you wife's account a prepaid number?
We can verify if it's eligible, simply send me her number (that she wishes to port over) via private message!
Thanks,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
