10-02-2019 06:21 PM - edited 01-05-2022 07:23 AM
Switched to PM last Friday Sept 27. It’s now the evening of October 2 and no service yet. I have contacted moderators twice. First gentleman moderator contacted me Sunday but did not reply back after I sent him info he required after he did a network update (he said he did). This morning I now have a lady PM on the case. No reply yet- I messaged 11:00 am and again this pm around 5. Does it usually take this long!?! Since I’m still without service will my account reflect this in regard to payment and next due date....I have so many questions...
Joining Public
10-20-2019 10:43 AM
@jillyradJail breaking would have no effect on phone number porting.
10-20-2019 10:14 AM
Did you Jail Break your device?
10-03-2019 10:36 AM
Ty
10-03-2019 10:34 AM
My sim works in his as well as mine☺️. His doesn’t work in mine. This is the second sim we bought for his phone. Now working in the third one. With the first one we just figured it was a fluke, but with the second we thought ‘oh dear, what can it be’ moderator has told me to purchase another one and send it to him and he’ll update it from his end. So I’m thinking we were just lucky enough to get two bad sims. As they say, ‘Third times the charm’! So cross your fingers for me🤞🤞 and send sOne positive vibes ✨
10-02-2019 09:15 PM - edited 10-02-2019 09:28 PM
@Linh You have reported that neither your SIM, nor his, work in your phone but both work in his. Clearly there is some setting in your phone that causes the problem.
Please put your SIM back into your phone, reboot the phone and report what message, if any, appears on the phone.
I suspect you will need to restore your phone so suggest you do a backup now. Restore options are factory reset or restore from backup:
- https://support.apple.com/en-us/HT201252
- https://www.lifewire.com/how-to-restore-an-iphone-577630
10-02-2019 08:53 PM
This is the second sim we bought for his phone so it can’t be another bad Sim... can it😮😮
10-02-2019 08:52 PM
Yes - I did all those. So I’m thinking it’s account thingy. I switched from a Koodo account(one account number) but with two different phone numbers and it was in one name, mine! Could this be it. my SIM works in his phone and his SIM doesnt work in mine...I’ve just explained all this to moderators so I hope this may be the problem. Life lessons - this is really teaching me patience and how ‘to just breathe’ lol🤞🤞
10-02-2019 08:47 PM
That's a pretty good indication it's your phone or your settings.
@GinYVR is great with iphones.
If you have tried Network Reset, IOS Update, Carrier Update, Airplane Mode cycling, Rebooting Phone, then you've tried everything I know.
10-02-2019 08:42 PM
@Linh wrote:I did everything except carrier update- how do I do that? (Pretend you’re answering a 2 year old)
You can manually check for and install a carrier settings update with these steps:
- Make sure your device is connected to a Wi-Fi or cellular network.
- Tap Settings > General > About. If an update is available, you'll see an option to update your carrier settings.
To see the version of carrier settings on your device, tap Settings > General > About and look next to Carrier. To see additional carrier information, tap the version number.
10-02-2019 08:38 PM
Oh yes I seen that- I swapped SIM cards and his doesn’t work in my phone but mine works in his. I had switched from one Koodo account with two phone numbers - so maybe this is the problem. Moderator informed so 🤞🤞🤞 < these fingers getting tired!! Lol
10-02-2019 07:27 PM
10-02-2019 07:24 PM
10-02-2019 07:23 PM
@Linh go in settings, general , about. If there is a carrier update it will ask you to update
10-02-2019 07:20 PM
How do I check for a carrier update
10-02-2019 07:02 PM
Check your system updates just in case. See if there is a carrier update. Try a network reset. Try cycling airplane mode and shutting off/turning off your phone again.
10-02-2019 07:00 PM
Ty ✌️
10-02-2019 06:59 PM
We got a good bye test from Koodo and a Helo text from Public mobile when we started all this...old SIM card does not work- no service
10-02-2019 06:55 PM
how about your old sim card? does it still work?
10-02-2019 06:55 PM
Iphone6. It’s my husbands. Mine is an iPhone 6 and it’s working fine. I just called the number that is supposedly working and I get a quick busy signal...
10-02-2019 06:53 PM
@Linh wrote:Thank you. I just got a message from moderator telling me they had done something in their end and to turn the phone off and on. I did it- still not working! Holy moly, eh!?!
What kind of phoone, btw?
10-02-2019 06:52 PM
My other phone was within in minutes-
10-02-2019 06:50 PM
I just transferred to PM, and it worked in few minutes.
Though I was told it usually takes 2 about hours.
Logined in the account, I even found there was some cost (calling, and data usage).
10-02-2019 06:50 PM
10-02-2019 06:45 PM
Your account may begin on the day you signed up and had no service. Ask the moderator if this is the case, and ask them for a credit for the days you have waited. They did that for my oldest son who waited 2-3 days.
10-02-2019 06:36 PM
Thank you
10-02-2019 06:35 PM
@Linh wrote:Koodo
If you are porting from Koodo prepaid, wait for moderator to help you.
At this point, even you are porting Koodo postpaid number, you need to wait for moderator since your port is stuck.
10-02-2019 06:33 PM
So Do you think I shouldn’t panic?🤞🤞
10-02-2019 06:26 PM
Koodo
10-02-2019 06:25 PM
No it should not, but sometimes it does.
Hopefully they will be back to you soon. Where did you port from?
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
