4 hours ago
- last edited
4 hours ago
Hi! I have the same issue. Authorised a port request from Fizz to PM over 8 hours ago, but have received no updates or confirmations.
4 hours ago
I have the dame problem, can you send me the number as well ?
4 hours ago
is your Fizz sim still working and can make an receive call? If so, the port was not completed yet.
There is a number to call to talk to live support, they can provide you the porting update and can re-trigger the porting request with Fizz if needed. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach someone from the live support with the phone number I sent you, you can also message them here:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
