01-01-2022 04:31 PM - edited 01-04-2022 04:41 AM
Hi, I switched freedom Mobil to public Mobil. I got text message from you to give you authority within 90 minutes but I did not reply YES. I was late to reply. Pl.send again text message request for porting number authorization. Thx.
01-01-2022 08:03 PM
Hi Rashida - I put my account number in wrong during the porting process and I ended up calling the 1-800 number for the Telus porting department who helped me through the problem. Good luck! nibor
01-01-2022
07:32 PM
01-01-2022
07:36 PM
computergeek541
@Braams wrote:Good luck thi happened to my father in law and it has been over 24 hours with no service. His old cell provider ported the number and public still cant xxxxxxxxxxx get him up and running
@Braams OP issue is likely different from yours. You have a SIM provision issue as well. Hang on to it , it will get resolved and it will be good from there. Again, it is not a prefer situation , but porting and activation sometimes run into issue with any provider.
01-01-2022
07:29 PM
01-01-2022
07:35 PM
computergeek541
Good luck thi happened to my father in law and it has been over 24 hours with no service. His old cell provider ported the number and public still cant get him up and running
edited by computergeek541: terms of service
01-01-2022 06:07 PM
01-01-2022 05:02 PM - edited 01-01-2022 05:02 PM
@Rashida wrote:Hi, I switched freedom Mobil to public Mobil. I got text message from you to give you authority within 90 minutes but I did not reply YES. I was late to reply. Pl.send again text message request for porting number authorization. Thx.
According to the process, you should receive another follow up text even after the first 90 minutes.
Ensure you have the previous provider's SIM in your device.
"we will automatically resend you the SMS text to validate the transfer up to 5 times between the hours of 11 AM and 8 PM ET. "
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
01-01-2022 04:33 PM
@Rashida there is a number you can call to re-trigger the process. I will send you the number via Community inbox, envelope icon on top right.
