03-01-2024
06:25 PM
03-01-2024
06:55 PM
computergeek541
I entered the incorrect IMEI (wrong slot) when I activated abd tried to port my number from Bell to PM.
03-01-2024 06:53 PM - edited 03-01-2024 06:53 PM
The V in circle is just right of your avatar but click to edit reply your post first on the V.
03-01-2024 06:52 PM
03-01-2024 06:51 PM
I don't see a way to delete or edit the message with the IMEI #
03-01-2024 06:41 PM
It is alway better and porting will go smoother if you use your old account from your previous carrier.
BTW, I would suggest you remove your IMEI as this is a public forum. Click the V in circle top right and edit out for your Samsung A phone.
03-01-2024 06:28 PM
Hello @JannyV
There is a number you can call to get this porting issue resolved. I will send you a private message to your mailbox in the top right corner of this page or click on this link to direct access.
03-01-2024
06:28 PM
03-01-2024
06:56 PM
computergeek541
The correct IMEI number is xxxxxxxxxxxxxx
03-01-2024 06:26 PM
The number transfer did not go through. How can I transfer the number after activation?
