09-30-2019 06:32 PM - edited 01-05-2022 07:21 AM
Port requested, all seemed good, even saw calls and txt from "ported number" but now calls go direct to voicemail. Its been more than two hours? Ask in to mods but any help would be appreciated.
09-30-2019 06:45 PM
Great question. Bell was work number, Public Mobile was activated for a short run a few weeks back for the us plan. Thought port over to PM easy peasy, thought all good because I saw the number in the usage area. Then I got an itch for an XR, and I wanted faster speeds so went to buy the phone. Mistake was doing all of this same day
09-30-2019 06:42 PM
@mpharand14- Just out of curiosity, why hop into PM if you are going to Koodo. Why not go direct rom Bell to Koodo?
09-30-2019 06:36 PM
Bell, its even more complicated than that. Today I had to do a port from bell business to consumer so that I could grab the number to koodo. doing a third port over to koodo, once public gets my number (long story) but PM was great and keeping my son on board
09-30-2019 06:36 PM
When you sign up, PM sets you up temporarily to send texts and call out. You cannot receive calls and texts until the port completes. Do you have the sim from your old provider?
If so, put it in and your old sim should work until the port is complete.
09-30-2019 06:35 PM
@mpharand14 hi it can take a few hours to port a number where where you porting from?
09-30-2019 06:35 PM
@mpharand14 wrote:Port requested, all seemed good, even saw calls and txt from "ported number" but now calls go direct to voicemail. Its been more than two hours? Ask in to mods but any help would be appreciated.
When you say direct to voicemail, is it the other carrier's voicemail? If it is, the transfer isn't yet done.
09-30-2019 06:34 PM
@mpharand14 - Ports can easilly take more than two hours. All depends on where you are porting from. Land lines & Voip lines take considerably longer than other cell providers. Some cell providers have been known to hold a port request until they have had a chance to try to convince person to stay with their company.
Where are you porting from?
