10-21-2016 05:37 PM - edited 01-04-2022 03:42 PM
Hi All. Just activated my SIM and per the instructions chose a new number as I will be coming over from Kodoo. Does anybody have the "next steps"? Hoping for a quick resolution as the time is ticking on the 90 days I paid for (no data left on my kodoo plan, haha).
I did try to search the forms to see if there was anything I should do but didn't find any clear instructions.
Thanks.
10-21-2016 09:20 PM
thank you.but i gave the email when he asked for the email support.
10-21-2016 08:39 PM
@TML2016 by the way, I see this thread is marked as solved, so I'm guessing @Mary_M was able to resolve this for you? Welcome to Public Mobile! 🙂 Please continue to enjoy the same great network but at a better price.
10-21-2016 08:33 PM
@jerinjohny1 I don't usually recommend people to use the email support, and prefer to suggest they post here and/or private message a moderator, as the service here tends to be quicker, and more consistently helpful. No offense to the PM staff doing the email support, but....
10-21-2016 06:10 PM
Hey @TML2016
I have responded to your private message, can you please view it ? 🙂
Thanks,
Mary
10-21-2016 06:08 PM
I think our moderator @Mary_M will be able to assist you this evening.
Hang in there.
10-21-2016 06:06 PM
[email protected] ,,email ur all details
10-21-2016 06:04 PM
It said that "we are experiencing difficulties processing this request - please contact public mobile".. so here I am - can anybody help or do i contact via email?
10-21-2016 05:50 PM
10-21-2016 05:50 PM - edited 10-21-2016 05:50 PM
Login to your self serve and you can request to port in your number. Make sure you aren't using the same email you used with koodo. If yes, change your email first than after posting is complete, you can change it back.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
10-21-2016 05:41 PM
do u want to port?
