Port New Phone Number
BC28
I am trying to port a number from Nucleus to Public.  I made the request to both carriers on Friday of last week & so far it is not working.  Nucleus says the problem is with Public & Public says there is no problem.
2 REPLIES 2
@BC28  Did you first make sure the number can be ported ?
Check to see if # can be ported
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
also did you leave old providers sim in the phone to reply YES to the confirmation text to port ?
I can send you the porting team number private message they can re trigger the port request if needed
slusagm
is Nucleus a landline or VoIP?  it takes longer for porting from landline or VoIP carrier, 3 to 7 days
you can ask PM porting assistance team for help, for update.  I can't post the number here but I will message you the number to your inbox in the community
