05-13-2026 02:56 PM
My points were used to collect data for 15 GB instead ofy intended use to translate it to a bill credit
05-14-2026 01:19 PM
Blue did not understand the issue
05-13-2026 02:58 PM
hi @Ash12345
it is all up to you. the points are in the Points account and only you can redeem the points yourself. So, you can redeem for points or data as you see fitted
