Point Redemption
Nissan_Zaman818
Hello, how can I redeem my point toward my monthly bill? Currently, I have 9 point on my accounts
2 REPLIES 2
will13am
@Nissan_Zaman818 , points are redeemed using the catalog.  Select an item from the catalog and redeem the specified points for the item.  In case of points to $, the redemption has to be done in batches of 15.
hi @Nissan_Zaman818
9 points not enough.  You need to collect to 15 points
when you have 15 points.  Login to My Rewards to redeem
To login my Rewards, go to My Account site, click Rewards on the top and it will bring you there
or you can use the app , go to Rewards page
