10-17-2017 05:51 AM - edited 01-05-2022 03:25 AM
10-17-2017 10:49 AM
https://activate.publicmobile.ca/
just go on the above link and fill out the necessary information and you will register your sim card in minutes.
10-17-2017 10:44 AM
Hey @rkarne!
I'm sorry you've been having trouble with your account activation 😞
If you're still having issues after following the instructions of our Community members, don't hesitate to send us a private message (click here!) with your SIM card number so we can help you out 🙂
Saray
10-17-2017 10:36 AM
Hi @rkarne!
I have edited your post to hide your email address. This is a public forum and you may start getting junk mail so please be careful about sharing personal info here.
Did you try activating at https://activate.publicmobile.ca ?
If not, I recommend you do so... just follow the prompts and enter the info. Ask if you need any specific help.
If you are stuck, send a private message to @CS_Agent and they will help you set up the new line.
10-17-2017 07:44 AM - edited 10-17-2017 07:45 AM
You need to setup the SIM card by activating it online. Go to the public mobile getting started section. You can follow the steps there.
