12-13-2020 09:50 PM - edited 01-05-2022 04:28 PM
Unlimited Talk Canada-wide - What does this mean and How does long distance work? Is it included across Canada with no min/max long distance calls at no charge for example when you buy a $25 plan?
12-13-2020 09:54 PM - edited 12-13-2020 09:56 PM
@tammyjosh wrote:Unlimited Talk Canada-wide - What does this mean and How does long distance work? Is it included across Canada with no min/max long distance calls at no charge for example when you buy a $25 plan?
All plans are unlimited calling and texting while you are in Canada except the $15 plan which has 100 outgoing minutes each cycle. The plans include unlimited international texting. You can call anywhere in Canada.
You can purchase additional add ons for international calling or US roaming packages.
12-13-2020 09:55 PM - edited 12-14-2020 10:15 AM
Correct on all counts. And to call from Canada to another country you need to buy an add-on package of minutes to accomplish that.
AE_Collector
12-14-2020 08:47 AM
Hi. You can call anywhere in Canada without being charged. If you go to the US, there are excellent packages you can add for calling, texting or data.
Enjoy Public Mobile, the perks and the savings! 😁
