Plan
BugieT
Hello, I'm having troubles with my plan. Last time I checked my add-ons nothing was wrong with my plan, but on February 1st my data hasn't been working. I just want to know what to do and how this could be solved.
Please I just need help.
-David
9 REPLIES 9
@BugieT wrote:
I'm on the 25 dollar prepaid plan with 2gb with auto pay
What does status mean?
My data total
My calling and texting but no data
I also beleive that there isn't any such plan. Either way, if no data amount is showing up in the Data and Add-ons part of your account, that means that it has all been used up.
@BugieT adding to @Jb456 queries, did your data ever work? Did you port your number ? And what type and model phone are you using? Welcome to PM.
Is it possible that the internet coupon was used to double the data?
My data total
@BugieT
First the $25 plan is 1gb of data not 2gb..T(unless there was a promo for extra gig or something?) $35 plan is 2gb...
Status means that status of your account.
https://selfserve.publicmobile.ca
Log into your account with that link..does the status say active, expired, suspended??
Also while in there scroll down to My Data and Add-ons....does any data show there... It would be like 300mb of 1024mb for an example.
BugieT
My data total
geopublic
-David
@BugieT  When data stops working it means that you have used the data allotment allowed by your plan. Your options are:
  1. Purchase a data add-on $30 for 1GB (expensive)
  2. Change plans to one with more data. (not a good choice if you have a grandfathered plan that you don't want to lose.)
  3. Renew you existing plan early. To do this you need to submit a ticket to PM and ask.
    To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
    If you are still having problems contacting Public Mobile then click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Staliger
-David
Check your self-service account. Does it have data or it is used up?
PAULRANG18
Quite likely data has run out. If so, a data add on will be needed to get through to the next renewal date. Could also wait for plan data to renew at next plan renewal date or use WiFi when needed.
kselmak
What plan are you on?
What is your status when you login?
What is listed in your add-on section?
What is working?
Jb456
In your account under my data and add-ons.
Does it show any data?? If not it means you used up all your data.
