Plan change
Todd72dewling
Hi
When you change your plan does it take effect ASAP or not til your current plan expires? Any info be great
thanks
2 REPLIES 2
Todd72dewling
thank you ..that’s what I wanted to be sure of before hand
MrSpock
@Todd72dewling Hi well that’s up to you , you can set it up to change now or change at next renewal
