05-15-2018 10:26 AM - edited 01-04-2022 04:17 PM
I have run out of data for my 90 days about 3 weeks short of the time. I forsee this happening each month now so I want to up my plan. I have nothing to lose by switching now and it is cheaper than buying the data addon. However, I have to top up my account for the full amount (instead of the autopay that I am used to using) in order to get the updated plan now. Will I still get my bonuses (autopay, loyalty, etc) or do I lose all of that?
thanks
Jim
06-12-2018 05:11 PM
We absolutely lost our loyalty points for doing this as a moderator pointed out. Nothing to be done about it, but I'll remember for the future.
05-26-2018 09:13 AM
I was not given the loyalty discounts and I was charged even more than the listed price. I have sent a private message to the the mods to get this sorted out. For those switching midplan, beware! You have to keep an eye on it.
05-15-2018 10:29 AM - edited 05-15-2018 10:29 AM
As long as AutoPay is enabled, you will not lose the AutoPay rewards. Topping up is just paying early and it does not effect your rewards.
05-15-2018 10:28 AM
The rewards will not be impacted at all by plan changes.
