07-23-2019 02:17 PM - edited 01-05-2022 06:03 AM
(Solution below) I reactivated my plan by topping up. I can connect to the PublicMobile network, but any call I attempt to make results in a recorded message saying that I need an add on for long distance calls, in spite of my active plan including Canada-wide calls! Similarly, any internet browsing automatically loads a PublicMobile page which has a list of reasons why data might not be working, but none of these apply.
What eventually worked was adding another $5 to my account. Now everything is turned on, no other changes were made.
Rather annoying that I can be paid-up by PM refuses to provide the service paid for until I pay them extra cash which I might not eventually use.
07-23-2019 02:30 PM
Yes. That's the other "trick" around here. Deposit another nominal sum and it somehow kick starts the service. If you had a cc on file then you could've done just a dollar. But it sounds like you used a voucher and that's the smallest amount.
Good job. And thanks for reporting your success.
07-23-2019 02:23 PM - edited 07-23-2019 02:25 PM
@dhigger wrote:(Solution below) I reactivated my plan by topping up. I can connect to the PublicMobile network, but any call I attempt to make results in a recorded message saying that I need an add on for long distance calls, in spite of my active plan including Canada-wide calls! Similarly, any internet browsing automatically loads a PublicMobile page which has a list of reasons why data might not be working, but none of these apply.
- My plan is Active in my account - the next payment date is weeks away
- APN for data is correct
- Tried suspending service then re-enabling after a few minutes and rebooting the phone (the Lost/Stolen phone feature/trick) - no effect
@dhigger The extra $5 that you loaded in your account will be automatically used up during your next renewal and AutoPay will only charge for the remainder. So to answer your question the $5 will get used up. ![]()
