01-09-2022 07:52 AM
My plan is showing expired and I am unable to reactivate it, I am on auto pay but have added funds. Can a MOD please have a look for me?
Thanks
01-10-2022 11:20 AM
Not here. This is not the way to contact the CSA's. And what is the date up top? And what is your plan?
01-10-2022 11:17 AM
01-10-2022 11:15 AM
@michaeldhewlett : So all your services are working and you see a date 1 month-ish (not upwards to 3 months) in the future but it still says Expired? Take a screenshot of your overview page and then contact the CSA's to have them switch your account to Active. This has come up as a bit of a bug recently. The screenshot is for proof of what you have in case something goes awry with your account.
01-10-2022 11:08 AM
but im unable to purchase add-on
01-09-2022 04:21 PM
Are you seeing this:
then it is normal (but confusing).
As long as you have service, just continue to enjoy PM. BUT if service is cut off for whatever unknown reason, come back here and wwe will try to assist or guide you to resolution.
01-09-2022 01:34 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent
Good Luck...
01-09-2022 09:57 AM
@sheshe60 wrote:It renews next on Feb 6th. I am trying to add a US roaming package.
@sheshe60 - Are you currently in the USA? Roaming addons are for services in the USA only.
If you are in the USA and you already had a US Roaming active for 10 days and trying to add the same one, you need to wait the full 240 hours after the first, same addon was purchased in order to buy the 2nd one.
OR, you can ask Customer Support to get it added for you, if this is your situation.
Methods to contact Customer Support found here:
https://www.publicmobile.ca/en/ns/get-help/articles/contact-an-agent
01-09-2022 09:53 AM
Here's what I'd do, @sheshe60
Ask the Customer Support Agents to manually update it for you if the system is not allowing you to make this purchase for the add-on.
PM generally frigs around with their self-serve backend systems over the week-end, so you may be caught up in their 'routine maintenance' which can be very hit or miss.
01-09-2022 09:51 AM
01-09-2022 09:25 AM
@sheshe60 wrote:I still have services and am on auto pay. I have added funds for the add ons but it simply says my plan has expired and won’t let me purchase any add one. I have reached out to customer support. Thanks for the replies.
@sheshe60 - if your services are still working, and if your renewal is today...you just need to wait likely a few more hours until your account fully renews.
What addon are you trying to add?
01-09-2022 09:21 AM
01-09-2022 08:38 AM
If your account was going through renewal last evening, and if you were trying to add and add on during this process, it's possible you may have just run into bad timing.
Allow the account to renew completely, taking funds from the payment card and in the morning if you were trying to add an add-on, try it then when the account status shows "active" and there are no expired or renewal messages displaying.
01-09-2022 07:59 AM
@sheshe60 wrote:My plan is showing expired and I am unable to reactivate it, I am on auto pay but have added funds. Can a MOD please have a look for me?
Thanks
@sheshe60 - We are members like you here, and cannot look at your account.
Your question about not being able to use an addon is confusing me. Which addon do you mean?
Do you still have services? If yes, this could be your account going through the normal renewal process. The SELF SERVE account can say "expired" or "suspended" on the day of or before your plan is due to renew.
So, if this is the case, ignore these messages on your SELF SERVE account.
If you have no services, and it is past your renewal, maybe your autopay failed?
If this was an Autopay failure, I would let the Customer Support Agents (CSA) know.
And, also ensure all rewards were or will be provided to you.
Methods to contact the Customer Support Agents (CSA): https://www.publicmobile.ca/en/ns/get-help/articles/contact-an-agent
