11-06-2018 12:16 PM - edited 01-05-2022 02:24 AM
Hi,
After my number goes into the suspended state and i recharge my account after 30 days will i be able to reactivate the same plan or do i have to start with a new plan.
Thanks.
Joining Public
11-07-2018 08:19 AM
Thanks a lot for the update
11-06-2018 12:19 PM
You keep your existing plan until you change it. Accounts can be suspended for upto 90 days. After 90 days you lose your plan account and tel number.
11-06-2018 12:18 PM
@mohammednadeem5 wrote:Hi,
Thanks.
@mohammednadeem5 yes--same plan and number. You technically have up to 90 days to reactive once your account becomes suspended but I wouldn't push it past 80-85 days tops just to leave some margin for error if you run into issues and need assistance from the moderator team. (More info on getting help should you need to at that time can be found here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745)
