12-13-2017 04:36 PM - edited 01-04-2022 03:06 PM
I tried to add on a 10 day US roaming and talk and text bundle ($20.00) for an upcoming trip to the USA. Can you tell me if this has been applied to my account? I leave tomorrow.
Thank you,
Filippo Berna
12-13-2017 04:48 PM
Thank you, problem solved with your assistance.
Regards,
Filippo
12-13-2017 04:42 PM
@filiberna You can check this by logging into your self-serve account and see the Add-On section on the Overview Page. Make sure that the $20 balance is not sitting under Available Balance. If it is, you will have to purchase that add-on again as it is a 2 step process.
