Pixel 2
01-30-2020 10:09 AM - edited 01-05-2022 09:15 AM
Just saw this on Amazon - Pixel 2 for 209.99. It is unlocked and would be a good inexpensive phone.
Phones
01-30-2020 04:02 PM
@popping wrote:
@gblackma wrote:@popping , I'm no expert on cellphones, are you saying that the price is too high for this phone? Thanks.
@popping wrote:This is a refurblished phone with 90 days warranty.
The used price is around $200 depending on the condition. The seller is Amazon Renewed. The 90 days is as good as the seller. But Amazon.ca will make sure the market seller will live up to its promise. It is better than buying from Kijiji.
I would say that that the main issues with a phone that could be a couple of years old would most likely be condiditon of the battery and possible screen burn.
01-30-2020 12:28 PM - edited 01-30-2020 12:29 PM
@popping I checked and it seems that Amazon or a division called Amazon-renewed is selling this phone. https://www.amazon.ca/Amazon-Renewed/b/ref=bl_dp_s_web_17351028011?ie=UTF8&node=17351028011&field-lb...
Edit which you already said in your post. Lol.
01-30-2020 12:23 PM
01-30-2020 12:07 PM
01-30-2020 11:42 AM - edited 01-30-2020 11:42 AM
01-30-2020 10:21 AM
Thanks @Triguy perhaps you can add some of the solutions to commonly faced problems regarding this phone such as this 😉
