01-26-2018 01:02 PM - edited 01-04-2022 03:24 PM
Hi All,
Just bought a Pixel 2 and wanted to edit APN settings but the edit settings are greyed out and I can't change anything. The settings don't match what PM has listed so wanted to tweak them. I also don't get the add APN settings option (the plus sign).
Any ideas would be appreciated.
Thanks
Phones
09-26-2018 05:36 PM
ok, i have similar problem with asus Zen Max Pro (M1) - there are default settings for telus and kodo and no way to change them. Also impossible to add new APN, as error pop up: "operator does not allow adding apns of type *".
Looks like glitch with Android 8.1. At least this forum helped: https://www.reddit.com/r/mintsim/comments/78usic/my_pixel_2_is_saying_the_carrier_doesnt_allow/
In short fix (workaround/hack ) was like this:
-------- And here is answer : ---------------------
If you're still having issues with this, I found a solution that works on my Pixel 2 running Oreo. When you go to create the APN, put all the info from Mint's site in. Instead of tapping Save, back out with the Home (circle) button. When you check your APN list again, it will be saved with the correct settings (if you tap on the APN name to view it, use Home to back out again, otherwise it'll come back up with the error). Select the APN to enable, should work fine.
01-26-2018 02:47 PM
I don't believe it's possible to edit the APN settings within the phone. The configuration file is read only. However, creating new APN settings should be allowed.
01-26-2018 02:25 PM - edited 01-26-2018 02:32 PM
@pboynett Why do you want to add APN settings? On my Pixel 2, I never changed APN settings and everything is working fine.
01-26-2018 02:04 PM - edited 01-26-2018 02:39 PM
wrote:Thanks. I assume the XL is the same as the regular Pixel when it comes to settings?
I believe all Pixel variations on 8.1 are seeing this (just going by a quick google search on that).
I wonder if it affects Nexus 5X or 6P phones with 8.1 too.
Edit: Had I bothered to read the same thread I linked I see it also affects 5X/6P as well.
01-26-2018 01:21 PM
01-26-2018 01:18 PM - edited 01-26-2018 01:20 PM
Unfortunately this is a known problem, please read:
The link does have a workaround that should help you.
I don't think the @CS_Agent ever responded in that thread so I am tagging here again.
