08-14-2022 06:50 PM
Hi
How do I change my 4 digit pin and register my number under a new email id?
08-14-2022 07:56 PM
Just did it, figured they would ask for the old one but they just send you a 6 digit security code to verify it, so we are good now lol
08-14-2022 07:11 PM
EZ to set up a new one. Log in to your acct / Profile / PIN / Enter new 4digit PIN / Reset PIN.
08-14-2022 07:06 PM
Do you have 3 opportunities before it locks you out?
Luckily I have never had to use 611 for payment but knowing my luck I will soon lol
08-14-2022 07:05 PM
If'n you ever want to pay using your on-file cc via dialing 611...you'll need pin number.
Good idea to have it written down somewhere handy.
**now where did I put mine !! 🤔
08-14-2022 06:57 PM
I just realized I haven't needed my PIN even once. I know it will be one of 3 or 4 PINs but don't want to get locked out, so will just knock on wood and hope I never need it 😕
08-14-2022 06:57 PM
contact to support team by CS_Agent
to change email and set new password and change 4 digit PIN.
08-14-2022 06:51 PM
@Jasmeet0707 wrote:How do I change my 4 digit pin and register my number under a new email id?
The account PIN can be changed inside your Self Serve account. To change your e-mail address login for the Self Serve account, a ticket needs to be opened by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
