3 hours ago
3 hours ago
@Turkstrak For OnePlus the first line in @softech 's instructions needs to be in all caps, that is SP.MB.COM
3 hours ago
Try Reset All Networks on your phone. And make sure mobile data is on
3 hours ago
was it working before? or you just subscribe to PM and never got it working? and did you just update the OS to Android 14? There has been some issue with OnePlus after the Android upgrade
With OnePlus, there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
