06-28-2019 02:09 PM - edited 01-05-2022 05:38 AM
i’m supposed to have picture messaging included in my plan but it never works.
06-28-2019 02:11 PM
@SilasXavier wrote:i’m supposed to have picture messaging included in my plan but it never works.
@SilasXavier You need to turn data on for MMS to work. Also make sure the correct APN settings are on your phone. These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
