07-07-2020 10:11 AM - edited 01-05-2022 12:00 PM
Does public mobile accept i phone 11 pro max , will it work with public mobile
Phones
07-07-2020 01:35 PM
Yes, it will definitely work as long as it is not locked to another carrier.
07-07-2020 11:03 AM
@Spinner Yes, such a modern phone will work with PM for sure. Don't worry and go for it!😊
07-07-2020 10:33 AM
According to this site @Spinner https://apn-canada.gishan.net/en/apn/public-mobile/apple-iphone-11-pro-max its 100% compatible has both the required 3g and 4g LTE bands. Make sure its unlocked and if transferring / porting your number over, your old providers account must be active to port your number. Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
07-07-2020 10:25 AM
It will work with PM. Make sure it is unlocked.
07-07-2020 10:23 AM
Yes, it'll work.
