09-16-2025 06:23 PM
When I try to call someone this shows up on my phone “do you want to call using your remaining line “. Press Call or Press Cancel So I can’t make any outgoing phone calls.
09-25-2025 09:41 AM
Thanks
09-16-2025 06:26 PM - edited 09-16-2025 06:27 PM
The message "Do you want to call using your remaining line?" appears on phone with Dual SIM when the system detects the line you tried to use for a previous call is no longer active, and it's asking if you want to use your other active line instead.
The reason is that your have not removed your old sim card from your previous provider yet. If the old one is a physical sim, remove it, if the old one is an eSIM, disable it. After you have done that, Reset network settings on your phone
