08-05-2022 11:03 AM - last edited on 08-05-2022 11:52 AM by computergeek541
My phone won’t let me call or receive calls or text out or receive texts…
something on your end… sim card? or something else… account is still active…
i tried it in another iphone and still won’t work.
thank you…
08-05-2022 07:11 PM
Did you just ported your old number to PM?
If so, you need to reply to the text confirming you are porting over to PM with the old SIM in your phone.
If it is an old account, try rebooting your phone by powering off the phone then back on. There also might be an outage in your area. Check outage map:
08-05-2022 05:12 PM
@gvickery - account is active, that's good.
Has any services worked at any point? Trying the SIM in the phone is a good test.
Check for outages in your area:
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
If still issues, submit a ticket to CSA.
Methods to submit tickets to Public Mobile Customer Support Agents (CSA) found here:
https://www.publicmobile.ca/en/ns/get-help/articles/contact-an-agent
