Phone will not accept calls!
02-25-2019 01:25 PM - edited 01-05-2022 03:29 AM
I recently recently reinstated my service to avoid loosing my number before the 90 day deadline! Everything seemed to work fine but when I called my nbr to ensure it was working all I continue to get is a busy signal, no ringing and no voicemail!
How do I get this rectified?
Phones
02-25-2019 01:42 PM
@Maverick-27_ wrote:I recently recently reinstated my service to avoid loosing my number before the 90 day deadline! Everything seemed to work fine but when I called my nbr to ensure it was working all I continue to get is a busy signal, no ringing and no voicemail!
How sure are you about the exact 90 days? From plan suspension or from the lost/stolen suspension?
02-25-2019 01:39 PM
- Dial *611 and see if there is anything
- Try the same SIM card in a different phone and see.
- Does your phone's carrier show as "Public Mobile" or something else?
02-25-2019 01:35 PM
@Maverick-27_ Did you ry restarting your phone after doing this?
02-25-2019 01:28 PM
Is your account ACTIVE in your self serve acount @Maverick-27_ ?
