11-15-2022 08:29 PM
I recently switched from a Samsung Alpha to a Umidigi a13 pro. Popped my sim in, texting and calling works, but my data wont work i can only use Wifi. Any help would be appreciated. Mobile data is on.
Service
11-26-2022 07:53 PM
After I setup the APN for Public Mobile I went and deleted the Telus APN and now my phone works just fine, the Telus one was setup when I started using my Umidigi A13 pro and seemed to be the cause of the problem
11-26-2022 09:27 AM
@humster It is an APN problem and Umidigi always have problem with APN here
Please go to the APN screen, update the APN entries as follow:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
11-26-2022 09:25 AM
I am also having problems, I switched from Umidigi A11 pro to A13 Pro and texting and calling works, Wifi only unable to use data for Mobile Plan
11-15-2022 08:31 PM - edited 11-15-2022 08:36 PM
@NicoleStates , a likely problem is with APN settings. Please confirm and correct the APN accordingly. See link below for APN settings.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
