08-10-2021 09:48 PM - edited 01-06-2022 03:05 AM
I attempt to transfer my phone number; however, I received a text stating that I entered the wrong IEM code. I don't know what to do now.
08-10-2021 10:39 PM
Thank you!
08-10-2021 10:18 PM
@clipoth wrote:I attempt to transfer my phone number; however, I received a text stating that I entered the wrong IEM code. I don't know what to do now.
Public Mobile Customer Support Agents can assist.
@computergeek541 provided the SIMon Bot method to submit a ticket.
This, and a private message to CSA are the two ways to contact Public Mobile:
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
I will Private Message you the Porting Phone Number, incase you can sort this all out this way. Although you are looking at tomorrow now, with the time of day, likely.
08-10-2021 09:56 PM - edited 08-10-2021 11:38 PM
The first thing to do is re-insert your old carrier's SIM card. If at all possible, it's your old carrier's account number that should be used instead of IMEI. To correct the porting error, please open a ticket with a customer support agent by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
