Phone number doesn't work--not a transfer.
Denisey
I cannot call my phone (the response is "number cannot be completed as dialed"). I also do not receive texts from Public Mobile to verify my account. This was a new phone number offered by PM. Any suggestions?
@Denisey   please open ticket with PM support as advised above then
Denisey
Yes I can make outgoing calls. I just cannot phone the cell phone. I called my landline provider and they checked the number. They said no one had been assigned that number.
@Denisey   landline provider?  I thought you said you didn't port in your number and just picked a new number
but again, can you make outgoing calls?
i still suggest you to open ticket with PM support and have them confirm if the account was provisioned properly
Denisey
I contacted my landline provider and they tested the number. They said no one is assigned to that number.
@Denisey
If you picked a new number with PM then just reboot your phone by powering off the phone then power it back on.
You will only receive a text if you are porting your old number over to PM but this is not your case.
You will get an email from PM welcoming you to PM on the registered email address.
@Denisey   so, you just joined PM with a new phone number and unable to receive calls?
can you make outgoing calls?  does Mobile data work?
What brand and model your phone is?
Try to change your Preferred network type or Network mode to 3G Only and see if it works
You can also try if VoLTE is setup properly.  Change the Preferred network or Network mode back to Automatic or 4G, then make sure you enabled VoLTE on your device
iPhone: Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Pixel Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
Also, if you have another phone, test your PM sim card there
if nothing work, it could be a sim card provisioning issue, please open ticket with PM support and have them to confirm if the line was provisioned properly
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
