Phone not working
11-26-2022 07:20 AM
Unable to make or receive calls. Started yesterday. We have 2phones doing the same
Service
12-04-2022 06:57 AM
Found there was no solution found by Public. Not an easy company to deal with. Asked a question and it was days before I got an answer that didn’t work.
11-26-2022 08:43 AM
they stopped caring a long time ago
11-26-2022 08:40 AM
@johnwang17627 wrote:The link you provided is not a link to re-initiate the port, it is a link to chat bot, which i have already created a ticket and waited for a century for someone to reply.
Please just save me and yourself time and private message me the number to help with porting.
I am on the edge of cancelling your service.
Just to be clear, I'm only a customer like you are - not a PM employee. All of us here are.
I was unaware you had already gone the chatbot route. Indeed the last few days have likely been extremely busy for all PM Staff.
I also sent you the number for porting in your private message box. You'll see it in the envelope icon upper right.
11-26-2022 08:27 AM
11-26-2022 08:24 AM
If you believe that's the case, to re-initiate the port, click here: https://urlshortner.tiia.ai/Lc9xk8
If this step above doesn't work, I will private message you the number to help with porting.
Hopefully you can use someone else's phone to call this number.
To check your private messages, look at the envelope icon between your avatar and the bell icon on the upper right.
11-26-2022 08:21 AM
Please just provide me the number to talk to live support as mentioned in previous posts yesterday already...i believe it is a porting issue...thank you for saving my time and your time.
11-26-2022 08:18 AM
Can you provide a bit more details?
Have you JUST ported here from elsewhere? Did you respond to the port authorization request from prior provider (with their SIM card in your device)?
Did you try rebooting device, resetting network connections, toggling airplane mode on/off?
You might also try the PM SIM card in a different device to see if perhaps a device-related issue.
11-26-2022 08:07 AM
where is support team...this is serious issue...do you guys not want to do business anymore?
11-26-2022 08:05 AM
def made a mistake this company is utter trash
11-26-2022 07:50 AM
Same here...two phones with reception but can not make calls or receive text...just ported from chatr on black friday...feel like i made the wrong choice...
11-26-2022 07:47 AM
We are having the same issue in New Brunswick 2 phones with Public suddenly no reception, restarted phone several times even switched sim cards between them and still same issue. please advise on solution. I understand this is a low cost carrier but for the love of god do you people not care at all?
