Phone not working
09-14-2019 10:15 PM - edited 01-05-2022 07:06 AM
Hi my phone suddenly cannot make a call and even my friends can’t call back to me by my phone number it always ask to let a message
Joining Public
09-15-2019 10:56 AM
Hi there definitely try swapping out sim card with one that you know is working such as a friends phone that way you will know if it is your phone or a problem with your service. Alternatively check that you are not out of minutes if you are on a limited minute plan. And if you are top up mins. 🙂 hope this helps
09-15-2019 09:35 AM
While your in self service look to see if your minutes line has disappeared. If so, this means your minutes are used up.
If this is the case purchase a $5 500 min add on as @geopublic recommended. It's a great investment for limited plans.
It doesn't expire, so it will help if this ever happens again.
09-14-2019 10:34 PM
@luanmyvan wrote:Hi my phone suddenly cannot make a call and even my friends can’t call back to me by my phone number it always ask to let a message
Log into My Account...is your plan Active or something else ? If the plan is Suspended, you'll have to add $$ to your account and Reactivate it.
Let us know if that's the case.
09-14-2019 10:18 PM
@luanmyvanCan you swap your SIM card to a known working phone to narrow down whether it is a Public Mobile issue or an issue with your phone?
09-14-2019 10:17 PM
@luanmyvan Are your on a limited calling plan? Maybe you ran out of minutes. If that's the case best to buy a 500 minute addon for $5.
