Phone not working
03-22-2019 09:47 AM - edited 01-05-2022 06:56 AM
03-22-2019 10:08 AM
@sandpublic wrote:
@Bindy211 wrote:My phone is not working and i put money on it 2 days ago
You might want to try the Losst/Stolen trcik to see if it fixes the problem. Just sign in to selfserve select the Lost/Stolen card option and select it. Logout wait for a couple of minutes then login into your account and remove the Lost/Stolen lock restart your phone and see if it fixes it. If not send a message to the @CS_Agent by clicking on the following link:
The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
@LuDevouges mentioned in another post that if you were on a legacy plan yo u have to login online and change your plan manually to a new plan. Make sure you select on next renewal so you don't get double charged.
03-22-2019 09:48 AM
